I recently bought a 2002 20i Direct Drive. Last month I made the mistake of running over a sand bar at the river and the prop (Acme 3 blade) didn't survive. So I switched over to my spare (Acme 4 blade). After doing this I noticed a slight vibration and loss of power, primarily during the hole shot when pulling a rider. This only lasted for a few seconds each time and everything else seemed to be fine. I thought the prop might be cavitating. I got my 3 blade fixed and put it back on. Now the problem is even worse. Not as bad as with the bent prop, but bad. I have a major loss of power and vibration every time that I accelerate with or without a rider. It happens during the hole shot and/or whenever I quickly accelerate at all speeds. It last anywhere from 3-4 seconds up to 30 seconds.
The props are straight and spin freely by hand. The drive shaft looks straight with no visible damage. The tracking fins do appear to be out of alignment. When looking from the back the front 2 are off center bent to the right. The third (rear) fin appears to be straight. Would this cause the problem I described? What else could it be?
Does anyone know how/where I can get it quickly diagnosed? I'm in San Diego and the boats at Martinez Lake/Colorado River (Yuma, Az.) The boat is new to me, so I don't have a mechanic yet. Can you recommend one that does not have a huge waiting list at this time of year? Thanks.
