Does anyone know if there is an extendable hose available for the bow walkthrough heater vent on a 2009 RZ2?
Heater hose for 2009 RZ2
Air hose, right, not the water hose?
The corrugated air hose can be bought by the foot, and shouldn't be too hard to swap out. This may be easier then trying to splice in an extension. Just a thought.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Air hose, yes. The 2009 RZ2 heater (at least mine) has a grill bolted into the bow walkthru. It does not extend -- but I want it to. Swapping out would be fine but what sort of termination would there be?
Originally posted by Iwndr View PostI put in a Heater craft
EDIT: Ok, now that I have learned how to use a web browser ... Ordered!
http://www.heatercraft.com/ProductIn...roductid=H521BLast edited by Duncan; 12-02-2010, 05:17 PM.
Originally posted by Duncan View PostHmmm, now I start to doubt myself. The guy at Heatercraft suggested the boat probably already had a pull out hose.
I am fairly sure I tried and there was no pull out. Boat is an hour away.
Anyone with a 2009 RZ know if there is a pullout heater hose with the stock Tige heater?
Originally posted by Duncan View PostYeah, I am dumb. I already have a pull out heater hose.
Hmmm, might keep that quiet and celebrate the "upgrade" in Spring so as to not have to answer "you mean we could have used that hose last on those cold rides back to the slip end of season?""Failing to prepare is preparing to fail" John Wooden- Rest in Peace
so on these factory heaters, where exactly is the heater installed. is in the the storage area in front of the captain?? If so would anyone mind adding pics as to where and what the heater looks like and is located. Im wanting to add a heater to my 08 RZ4, but want everything to look as factory/clean as possible
Originally posted by joaquin12345 View Postso on these factory heaters, where exactly is the heater installed. is in the the storage area in front of the captain?? If so would anyone mind adding pics as to where and what the heater looks like and is located. Im wanting to add a heater to my 08 RZ4, but want everything to look as factory/clean as possible
The controls were installed right below the Throttle and Ballast controls."Failing to prepare is preparing to fail" John Wooden- Rest in Peace
