Most of the folks here know I have a excel file for winterization of the 350 MPI EFI engines. Well my computer went out several months ago and I lost my updated copy. I am in the process of updating my old copy now. I like having a step by step file just so I don't forget to do something.
I just got finished winterizing my boat and I have a couple of questions for the experts.
1)I take the 4 hoses off the top of the engine right at the thermostat. If I pull all 4 hoses off and pour RV antifreeze in these hoses, does the antifreeze get to the vital areas that it needs too? I use a total of 2 gallon of antifreeze in these hoses, is this enough? (I do not remove the thermostat to do this)
2)I decided to remove the tension off of the serpentine belt for the winter, is this a good or bad idea? and why if not?
3)I also notice when adding the antifreeze to the hose that goes to the fuel cooler (bottom right side of the engine) that it didn’t take much antifreeze. Will the antifreeze go through the cooler and protect it?
4)What is you opinion of Sierra oil and filters. My marine dealer was out of Quicksilver oil so he gave me Sierra 25-40w blend and a Sierra oil filter. How can I tell if this has the moisture inhibitor in it like the Quicksilver does? (still have the empty bottles)
I will start w/ this for now.
Thanks
Dale
Thanks
Dale
