gonna be winterizing pretty soon need to know if i need to pull the temp sensor on the starboard side of the block the port side has a pitcok and do I need to pull the tranny cooler lines or just pull the plug on that heat exchanger any other tips would be helpful. boat has no heater or anything so if that helps.
winterize ?
