The 2004 Tige Switch V? How is it different from the 2004 20V ?
What is the definition of a Switch V?
First and best, the 2004 switch V has a slightly different hull. ( more rocker then the 2004 20 V)
(The switch v hull became the 20V hull in 2006 I believe).
The switch V has a walk through bow; the 20 V has a seat there.
The 20V has nicer interior then the SwitchV.
The 20 V has two speedometers, where the SwitchV only has one.
The SwitchV was designed as an entry level boat. (No thrills, base model)
So yes the 20V is a nicer boat, but I really love my SwitchV. On the 2004, the cushion on the noise opens up. (Changed in 2005) also the 2004 has a 38 gallon tank (2005 only has a 25 gallons or so)
The switch was only made for 2004 and 2005. (Not sure why they canceled it)
they made 3 models V, I , and CI ( the Ci had a closed bow)Tige, it's a way of life!
Here is a link to a review by waterskiing magazine
http://waterskimag.com/ski-boats/200...2004-switch-v/
“Size does matter, but strangely enough, sometimes smaller has its advantages. The Tige Switch V isn't one of those monster wakeboard boats. Instead, it delivers the goods without the bulk. It's a fun boat because it handles like a sports car- we found it to be nimble and fairly solid, with a high freeboard design. It also turns well while fully loaded.”Tige, it's a way of life!
