I am trying to figure out what the 2 accessory switches on my instrument panel do? i have 1 on each side of the steering wheel. do they turn on the 12v outlets in the rear storage comnpartments or are those always hot? are the accessory switches for something else? i dont have ballust, led kit, etc etc, just a base 2009 22ve.
Accessory switches
I believe "Ryannjena" is correct.
The 12 Volts should always be hot (when batteries are on) and Tige puts the same switches in each boat i think, you can look on thier backs to see if anything is wired into them, if not they are there for future wiring. You can add accesories and run them through the rocker switches.
