I have a 2004 Tige 21i and we adding a set of Monster Double Barrel Tower Speakers along with a new Clarion 480 Amp. Can Tige supply a wiring diagram? It would be nice to be able to identify all of the hot leads, etc. Also, what is the best way to access the speaker wires through the tower rear mounts? With 21i full gunnels, access appears to be tough!
Wiring Diagram
You should not need a wiring diagram, just hook the amp directly to the battery. As far as running wires through the tower I have a 04 22i and I had to take my tower off and run the wires, there are holes in the deck and in the bottom of the tower but the hole is hard to put something in because the tower tube diameter is larger than the hole for the wire. As far as the gunnels go, reach behind them or hook your wire with a wire cloths hanger.I'm on a boat man. I got my flippy floppies....
