Hour meter on 01 Fox Racing?
    I am currently in the process of purchasing an 01 Tige 21V Fox Racing edition. The owner stated there are apprx 100 hours on the boat. I had a surveyor inspect the boat also, come to find out that both the owner and the surveyor could not located the hour meter? Does anyone have any idea where it is located???? Thanks!
    It is located in the 4 in one Faria gauge or the Pilot gauge. It is in one of the sub menues but is not very accurate. You will need to plug in to the ECM with a DDT to get the correct hours.
      Definitely don't trust the Faria hour meter on the dash, it's a joke. Mine reset it self after 150 hours, others have reported the same thing.
      Tip
      -Tip
        have a shop scan the ecm. it logs engine run time and run history. the only way to change those readings is to replace the ecm at a hefty price.
        Greg Denton
