How do i find out my engine temperature on a 2009 22ve? There was no digital gauge on the lcd screen and i couldnt find any button to push to make it change? Does it not display that info anymore? If not, why not? If so, where is it?
Temp Gauge--where's it at?
If I remember correctly off the top of my head, with the SpeedSet toggle switch off, push the up or down SpeedSet arrows to cycle through several informational displays. One or more of those will show engine temp, oil pressure, etc.
That is assuming it is on the "main" display. If you have it on another display, such as depth, then you need to press the center SpeedSet button, use the up/down arrows to cycle to "main", and press the center to enter that display.
It't there all the time on the screen.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by light200 View PostNo, I disagree, it's not on the screen at all which is why there must be some button to display it or change displays?
When the one gets back from a ride, i'll see if I can snap a pic.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Its on the time display in my 09 RZ2. Hit the speed set button to switch display screens, then toggle to time display and hit the center speed set button. This is the only location this important info is displayed. It cannot be displayed if cruise is turned on. IMO, major human factors design interface fail!2009 RZ2, PCM 343, MLA Surf Ballast, Premium Sound.
Originally posted by Ewok View PostIts on the time display in my 09 RZ2. Hit the speed set button to switch display screens, then toggle to time display and hit the center speed set button. This is the only location this important info is displayed. It cannot be displayed if cruise is turned on. IMO, major human factors design interface fail!I thought temp display was default each time the key was cycled, so it was there till you scrolled away from it.
Nope, this was an important fact my dealer went over with me in detail to keep an eye on the engine temp during the break-in period. When you turn on the key on the main screen you get redundant info from the analog displays but no engine temp. You get outside air and lake water temp but no engine temp.2009 RZ2, PCM 343, MLA Surf Ballast, Premium Sound.
Originally posted by light200 View PostOk that's great, but nobody has been ablest answer the original question yet, which is, HOW do I display it and where does it actually show up.?
Light,
Sorry if my first post was not clear or you may have a slightly different dash than I do. My dash only has 2 analog gauges, speed and tach. There are LCD screens under each analog gauge and a much larger LCD screen between the gauges. If you have the same set-up, here is how you access the engine temp gauge:
1. Turn on engine
2. Ensure cruise control switch is OFF
3. Press the center button on the speed set control
4. You may now slew through the 4 menu options on the center LCD screen
5. Use the up/down arrows to find the TIME display option
6. Press the center button on the speed set control to select the TIME display
7. The engine temperature will be displayed in a small box near the top of the display.2009 RZ2, PCM 343, MLA Surf Ballast, Premium Sound.
