I just was told that the seal in my water pump may be going bad and the pump could need to be replaced.
In my 21i the access to the jabsco pump is about as good as it gets, but is this a repair I should dare try on my own?
Also, is there any way to check or replace the seal instead of just buying a very expensive pump?
