Could a bad IAC valve cause the boat to die once it is at top speed.
Bad IAC valve
Nope. It's either a loss of fuel or ignition.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
I am getting so frustrated. I took it to a boat shop and at fisrt they told me it was the fuel pump, and maybe the fuel cooler, and that the IAC vavle was bad. Then they called back and said that they got the fuel pressure where it should be. So they told me that it was just the idle air control valve. But that made no since to me. I thought that was just for the idle. My wife and I are looking at a very glassy lake right in front of our house and can't do anything about it. Very frustrated.
Originally posted by ereed969 View Postdo those valves go bad or can you clean them. And I thank you for your adviceMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
A bad IAC will cause the boat to run rough or stall at IDLE. When there is no throttle, the IAC opens to let enough air through so it won't stall. If it is dirty or clogged, the motor will choke out.
or cause it to "hunt" for idle... but not stall at WOT/top speed
hence IDLE valve.... It is just a bypass for once the throttle is closed to still let air into the motor so it can keep running/idle
If you are at full throttle and slam it into neutral or let off the gas a lot and it stalls you probably have a stuck IAC. ( throttles closes but still needs a lot of air to keep the motor running so IAC opens all the way up if it is stuck lack of air will make it stall)
Originally posted by lohe View Postor cause it to "hunt" for idle... but not stall at WOT/top speed
Originally posted by laserfish View PostWhen was the last time you put in plugs, wires, and distributor cap and rotor? I did that this year and it made a world of difference in perceived power and ease of starting and idle. Distributor cap was in really bad shape so bought a new Mallory cap and rotor.
If you have a durty throttle body then yes a bad IAC will kill the engine. Clean the IAC and throttle body! Your boat dies at top speed?
So it runs fine as long as your not wot ? Or it dies when accel? Dies how? shuts off or starts missing or ? ??? More information of excatly what it doeswww.1320diesel.com Home of the Fastest Diesels!
Originally posted by h2osk8er00 View PostI put new plug wires.. but the rotor and distributor cap have been the same for maybe 3 years.. same as the plugs I believe..www.1320diesel.com Home of the Fastest Diesels!
