It might help to add what is called a flashback diode between the coil of the relay and or the fuel pump. Maybe someone with a little bit more electrical knowledge than I can explain this better but I will give it a try. When you apply voltage to a relay to energize it, you are charging a coil that magneticly pulls in the main contacts, the trouble happens when you remove the power to that magnetic field, you basically have a minature version of the coil that fires your spark plugs. Think about it, a ignition coil fires when you remove the voltage to it. It can make a little backwards spike in your electrical system or it could make the relay ring (switch the contacts on and off quickly) and when you are running something with a high current draw like a fuel pump it can weld the contacts together eventually because you are making an arc when you open and close the contacts. Circuts do not like to be broken, that is what the condencer in a points sysem does.
What you would do is hook up a small diode between the two coil leads on the relay. You would point the arrow on the diode so that you do not create a direct short, ie; arrow flowing from neg to pos and blocked. This gives the coil a path to harmlessly collapse into. The same thing can be happening on the other side in fact it may be more likely that when you shut off the fuel pump it also has a magnetic field that needs to go somewhere, otherwise it turns into somewhat of a generator for a split second and becomes a mini welder trying to fuse the contacts together on the relay. I dont know for sure but there is probably a diode in the harness somewhere and it has opened up. You would just do the same thing and put a diode between the two wires going to the fuel pump, just be carefull and put the blocked arrow in the right direction or you create a direct short and wires will suffer.
Let me know if this helps.
Ray
Ray
