I did a search but did not come up with what I was looking for. I have 2008 22ve that the speedometers are not working. It has analog and digital speedometer gages. I replaced the paddle wheel but it still does not register speed. The temp and depth all work so I know the transducer is partly working . Hopefully someone can help me with these questions.
Is there a way to check the wire for the speedometer coming from the transducer that will tell me if its the transducer or not?
Is there any other common problems I should be looking for?
Thanks for any responses
