I have to remove fuel tank to access TAPS cylinder hydraulic lines. Everything is stripped out except the rear seat bulkhead. Its wedged between the top edge of the tank and the L&R ends. You can only lift it up about 3/4" before it hits the hull, no L or R movement available. How do you remove it?
The photo below is not my boat but is exactly the same without the bulkhead.
