2013 Tige RZR - 141 hours
Took the boat out over the weekend. Saturday, no issues. Sunday, the big lake was pretty choppy and heading back we hit some hard waves but kept on going. At some point heading home the Tige You froze and the gauges were still lit up but not reading any values (fuel gauge, temperature, taps, speedometer all with no value). Once we got back in the harbor I turned the boat off and tried to restart it. Gauges and Tige You started up normally, crank battery was reading 12.3 amps on the screen, however the boat wouldn't even crank. Battery switch was turned to "On". All batteries are new as of July.
1. Checked the throttle in neural (all the way forward and then click back into neutral)
2. Checked the kill switch lanyard
3. Checked the fuses underneath
4. Tried to jumpstart with some other people on the water
5. Got home after a tow and checked the crank battery with my voltmeter and was getting 12.7 amps
I did not test the boat batteries in combined mode.
Any thoughts on what could be wrong? Anything I should have tried differently while I was on the water?
