Reaching out to the forum for tips to gain access in the rear port side ballast compartment in order to disconnect the rudder and clamp block from the steering cable?
Does the rear ballast compartment plastic wall with the battery switch need to be removed in order to gain access?
All tips with experience working on the R21 steering cable greatly appreciated......! It looks likes it going to be very difficult.
