Boat Won't Start
    Boat Won't Start
    My boat won't start, any suggestions before I try some things tomorrow? 2016 RZ2 Raptor 400. When I turn the key, engine doesn't even try to start. I hear no other sounds. We were using it all day, had it turned off to relax for awhile, went to turn it back on and wouldn't start. The screen turns on and blower works.
    -Replaced the starter last year (old one clicked when I turned the key)
    -Did try starting it when battery switch was in Combine position
    -Shifter is in neutral
    -Kill switch is in the right place
    -Replaced both batteries after it happened (connections should be tight) and same problem
    -I have not checked any fuses, where do you find them on the engine?
    -Not knowledgeable on how to use a multimeter or what to even check but will give it a shot if you can point me in the right direction
    Things I’d recommend some you may have:
    1. Check Battery connections/voltage and look for corrosion
    2. Neutral
    3. Kill switch (normally a buzzer sounds)
    if you don’t own a volt meter go get a 30$ one from Lowes/Home Depot/Ace Hardware
    Or take batteries local parts place to validate they are in good shape
