Hi All,
I just had a couple quick questions regarding a steering cable replacement before I get in too far over my head.
Took the boat in for summerizing and got a call from the shop that the boat is due for a new steering cable. Makes sense, I know it was pretty stiff to steer at the end of the season so I'm sure that's the case. The shop quoted $850 for the replacement which seems a little steep to me. I'm plenty mechanically inclined and have no problem doing something like that myself, but this would be something that I haven't done before since this is our first boat. After reading a handful of posts it seems as though it's not a terribly hard job to do yourself, but the majority of posts were on newer boats. Does anybody know if there is anything different about the way the cable is set up/routed on an 08 RZ2 to make it any more difficult than any other? Of course that's assuming a previous cable wasn't installed in some sort of complicated way. I just don't want to get halfway through the job and then realize that it's way more work than I had anticipated.
Also, I read several posts saying that a longer cable is better, is there any specific reasoning behind that? I'm having a bit of trouble trying to track down an exact part # to purchase, I know the Teleflex brand is what is normally used and the "extreme" version is preferred.
Thank you!!
Thank you!!
