I am having an issue that the heater won't turn off. Always on even if the panel off! All I can control is the speed, low or high. The touch screen shows "Off" but keeps running in low. The only way to turn it off is to pull the fuse. has anyone figured out a solution without replacing the main board?
Cheers
Cheers
