Hi guys! Recently bought an older Tige V drive. Noticed ducts coming from cowlings in front of windshield direct air into seating area but none of them are routed to the engine compartment. There is a blower in the engine compartment, but I’m concerned there isn’t enough ventilation when cruising with the blower off. Is this normal? Thanks in advance!
Ventilation - passive & active needed?
Those front intakes should have hoses running into the bilge for forced air movement while underway.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
- 1 like
All to the bilgeMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
- 1 like
