We just bought a 2014 z1. this is our second tige and we love it.
but for some reason when the key is in the aux position we get two warnings
1. says low battery voltage, showing 1.5 volts on the crank and 12.5 volts on the house. But when the key is in the on position or when we are running the warning goes away and both batteries show 14.5 volts. I changed both batteries to make sure it wasn't that. also we forgot to turn the batteries off and had to jump them, but they charged right up, so no alternator issues.
2. the second warning says can data loss ignore if in AUX, the funny thing is it only comes on when the key is in the AUX position.
any thoughts? should i be concerned?
the boat runs great no problems at all just these two warnings.
thanks in advance.
thanks in advance.
