Hello, 2012 tige touch screen can be seen only very faintly. Worked fine shut boat off and restarted a minute or two later since then you can only see the screen faintly in the right lighting. If you can make it out or know where the icons are it will still control the boat. Has this happened to anyone else? I am thinking it is the screen itself but wondering if it could be the blue medallion viper controller under the dash. Any help would be appreciated
Tige touch screen almost dark
