Velvit Drive 71C
    Velvit Drive 71C
    Anyone have info on rebuilds, or new. Rebuilt mine and goes in forward and reverse but once I throttle up it slips.
    Not sure if velvet would help on this or not. Worth a call to them.
    Oh Yeah!
      What did you rebuild when you rebuilt it?? Did you do new clutch packs??
        Did stage 2 rebuild kit. Ordered hole front end pump kit and hopefully that fixes the problem, there is scaring in the pump and on the forward reverse adapter. The pump gears are also worn so I’m thinking when the fluid blew out and the leak over time killed the pump gears.
          This was when getting ready for re assembly.
            So finished rebuild for second time, pressure was great but still slipping at 1500 RPM, at a loss at what I’ve done wrong.
