I've had a 2016 RZR for 3 weeks now - everything has been working great - no problem getting good surf wave both sides at factory settings. Then today couldn't get a wave either side! Centre Taps working but neither side actuator would work. Went into dealer mode 'surf demo' and still nothing either side. Took the sad kids home... Then I reset all power and voila, entire system seemed to reset. At the dock in 'surf demo' actuators were moving according to taps setting. So then we tried to surf again. I could get a good wave goofy side but nothing regular. Went to 'surf demo' and am now getting different actuator readings for each side at same setpoint (see pics). My questions:
-Is there a way to 'hard reset' the Lenco actuators / surf system?
-Can I manually override the settings somehow?
-What should the actuator settings be for various setpoints (i.e. if I'm setting up to surf regular side then STBD actuator should be deployed, PORT actuator at 0?)
-Do I have a software problem and/or need an upgrade? Is there a way of doing this short of bringing to a dealer?
-Could I have a bad Lenco on one side causing feedback/control issues?
It's very frustrating that 'surf works then it doesn't'! I'm happy to hear any suggestions!!
