Small SS cable attached to rudder linkage
    Have a small stainless steel cable attached to the top of my rudder linkage that has come disconnected at other end.
    I think it is a ground cable.
    Does anyone know where the other end attaches?
    2013 Z1
    Do you have an anode on the taps plate?
    From what I recall you should have a few cables that tie together at the taps plate inside the boat. Rudder, steering cable mount, rudder box, swim step brackets.
    Oh Yeah!
      Looks like the only thing left is a 3ft cable to the rudder box.
      Bought the boat used.
      Is it something I should replace? Is it for ground or corrosion prevention?
        Corrosion prevention. IIRC it terminates at the ground bus bus bar. If you find a ring terminal on the bus har with nothing in then you know for sure. If you arent marina stored or in the marina much I wouldn't stress on it.
          Thanks
