I believe its the original shaft seal has started to leak and more so in surfing trim. It currently doesn't have the positive water cooling barb and PYI says Tige opted not to use the water cooling option as it will get enough water to cool the seal. I've done a lot of research and the more i dig into it the more I'm unsure what type to replace it with (positive cooling barb or just standard seal no cooling barb).
Who has replaced there non barbed PSS seal and what did they go with?
