thank you bell
Engine Popping/Backfiring
Ok, my computer has for some reason uninstalled the audio driver, so I cant hear the audio in the video, but I do have one question about how you checked the timing: Did you disable the ecm control and put the module at base timing before hitting it with the light?
Also, did you watch the timing light while duplicating the problem? If the light misses a beat, change to a different plug wire and try again. If the light still acts erratic, it's probably a bad pickup or module.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by da.bell View PostIf this help Chpthril, the video sounds like he is rev'ing the engine and 80% into the video, the rev'ing is reduced and you hear a definite backfire.
man, i'm still feeling secondary ignition, only thing left are plug wires, right?Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by bagzzz View Post600 RPM - at the T in BTDC
800 RPM - 12 degrees
1000 RPM - 12 degrees
1500 RPM - at the B
2000 RPM - at the D
"Idle timing should be set below 900 RPM. After initial timing, the advance starts approx at 1000RPM and increases to a maximum of 14 deg BTDC. Plus the initial setting of 8 deg, for a total of 22 deg BTDC. This advance occurs between 1100 and 2500 RPM." ~Seloc Service manual
A weak valve spring may not "slam" shut at high Rpm's either.
Good luck.The luck is gone, the brain is shot, but the liquor we still got.
Ok, so I received and installed the wires and nothing changed...
Here are a few more things I noticed that may help:
Every once in a while, you can barely hear (more like feel) a deep explosion when the boat is idling. It is not very noticeable, but when it happens the engine hesitates for a very quick amount of time.
There was some pretty rich white smoke coming from the exhaust and the port side exhaust manifold was much warmer than the starboard side.
Not sure if this is going to help at all. I am about to take the boat into the local mercruiser dealer but they will not be able to even look at it for another couple of weeks. It is 85 degrees and sunny here...
Originally posted by bagzzz View PostOk, so I received and installed the wires and nothing changed...
Have you put a timing light on the coil wire? if the light misses a beat when the probelm happens, you are looking at a module or pickup.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
The light did not show any hiccups when lighting via the coil wire. There is a really rich fuel smell when the engine is running. I am now on the waiting list for the local marina here, but it is a 2 week minimum wait. Is there anything else I can do in the mean time?
I am thinking about rebuilding the carb (I am coming from 7,000ft to 1,000ft), but I think that is a little beyond my mechanical ability. Does anyone know of where to find a good step-by-step manual for rebuilding these older Weber carbs?
bagzzz, you will get better advise on the engine problems from others, than what I would suggest. But I wanted to say sorry about the ankle. I assume that you are a pilot, so that has got to really suck. I love Lake Amistad and what a great place for a skier to be stationed. My daughter and son-in-law were there until last year. Did you ever see a '95 Ski Nautique in the storage yard? It was theirs. Good luck.
Originally posted by Paublo View Postbagzzz, you will get better advise on the engine problems from others, than what I would suggest. But I wanted to say sorry about the ankle. I assume that you are a pilot, so that has got to really suck. I love Lake Amistad and what a great place for a skier to be stationed. My daughter and son-in-law were there until last year. Did you ever see a '95 Ski Nautique in the storage yard? It was theirs. Good luck.
