Hello all,
I have a 1996 Tige with a 350 Magnum Tournament Ski engine. I live in South Texas so I have been taking it on the lake every week until mid-January and there has been no problems. I replaced the starter and changed the oil after the last session. The boat took about a month off, then I took her on the lake again this last Monday.
When I accelerated, there was backfiring/popping coming from the carb area. If the boat is in neutral, the engine RPM's can get up to 4800 RPM no problem, but once there is a load on the engine, the problems start. Today, I took the spark plugs out and cleaned them a bit, but they did not seem that dirty. I also took the carb off and I am going to clean that tomorrow.
I did a search of this problem and many people say it is the computer and/or a lose ground. I did disconnect the battery when I changed the starter, but it is secure now. Does this 96 carb engine even have a computer? Thanks in advance for your help.
