Hello all! i'm new here.. just bouthe a 2005 22v. put it in the water 3 times so far. I noticed a wet spot on the floor that re-appears every time. What do you guys think??? The hull does not fill up with water. i am at a loss of ideas. it is right by the cup holder nearest the cooler on the floor. i thought maybe it could be the cooler leaking but cannot find anything. is there a way to remove the gas tank access hatch to check it out under there??
Thanks in advance!
Thanks in advance!
