Pulled off my IAC (idle air control valve) off my 2003 6.2L Mercruiser Black Scorpion to hopefully clean it and fix my idle problem. Idles really slow and dies when I move into forward/reverse.
In removing the IAC I have damaged the gasket
. This gasket has mesh on it. There is no gasket in Australia.
My question is what is the role of the gasket mesh. Is it to filter or something else. I know its not ideal but I could make the gasket by cutting it out. However the mesh is a little tricky and I could just lay the mesh over the gasket if it is indeed required. Which side of the gasket would be best to lay the mesh (iac side or block side or doesn't matter).
I have read many posts re the IAC but not many mention this gasket.
Thanks in advance guys.
