Finally found the taps resovoir for my 2002 22I. It was low so I took out the fill plug to fill, (I assume its the fill plug, small plug with two small indents in top for a special key). However, the fill hole is very small, less than a 1/4". How are you supposed to add fluid through this?? Even using a funnel, it's going to be a mess. Any suggestions as the best way to do this.
Thanks in advance?
Brad
Thanks in advance?
Brad
