I've had a problem with rough running between about 1200 and 1500 rpm when in neutral. you can really feel the boat shake. This is a 2007 20V. Smooths out over that range and below.
I've had the dealer look at it twice, and they claim to see no problem. Figures.
It almost sounds like its missing on one cylinder. Boat only has about 30 hours. I *know* the dealer should fix it, but here is what I plan to try, would appreciate any other suggestions:
- Replace the spark plugs (never done, with 30 hours and platinum plugs, they should be ok?). See if any look funny.
- Replace ignition wires.
Any other obvious simple things to do?
Thanks.
Thanks.
