Has anyone got any experience changing the thermostat on the mercruiser 350 mag mpi? It is a 2001 model.
Changing the Thermostat
yep, The thermostate is held in a plastic housing inside the thermostate cover. I used WD40 and worked slowly and carefuly to get the old one out with out breaking the plastic. Take the thermostate with you to the auto parts store. It is smaller in size than a standerd 350 chevy. I alos had to use a razer knife to modify a gasket from the standerd chevy gasket. Good luck.
Got the problem fixed, put on a new impeller and housing. I did not think that it was the thermostat but I wanted to go ahead and find out what it would take to replace it because I was on a mission to get on the water yesterday. We made it out and the boat ran good other than a vapor lock issue, cooled the engine and was underway again. Don't know how I am going to fix that I just put on a new fuel pump/cooler and pressure regulator. The funny thing is that I had a buddy go out with us on his boat in case I needed a tow or anything and on our way back to the ramp his boat broke and I actually had to tow him back. He has an I/O and we think the shaft on the outdrive broke. It will be fun to fix. As always thanks for all the help.
Originally posted by jchurch6713 View PostWe made it out and the boat ran good other than a vapor lock issue, cooled the engine and was underway again. Don't know how I am going to fix that I just put on a new fuel pump/cooler and pressure regulator.Cursed by a fortune cookie: "Your principles mean more to you than any money or success."
