So, I've had my boat for less than 3 years - I purchased it brand new, with trailer at Stateamind in St Louis. The boat is a 2006, 22VE, 340 HP - sitting on an EZloader Illusion trailer. The trailer itself has roughly 1400 miles on it (mostly from a few trips to St Louis for maint) - my year round storage garage is 3 miles from the ramp. As I was pulling out of the garage 3 weeks ago, the tire began to rub on the fender - long story short, I discovered I had a bad torsion spring, luckily I was still in the parking lot and could garage easily. I ordered a new axle from EZ Loader and tonight we started to replace the axle. Well, when I took the wheel off I realized, that the back axle on that same side was also exhibiting the same conditions... Looks like the torsion spring went out on that wheel too! This left me befuddled (among other things), so I checked the weight capacity of the trailer = its rated for 4400 lbs, and GVWR of 5700 lbs. This sounded small to me, since I know the boat hull is heavy. All the literature I can find, says the boat weighs 3982 lbs. Add 450 roughly for a GM 5.7 L - and who knows for the MarinePower add ons. Then add 300 lbs for fuel, it has a 50 gallon tank, at 6 lbs/gallon. Boat+engine+fuel = 4732 lbs - plus wakeboards and misc equipment, I would say the boat is around 400 lbs over the capacity of the trailer and the GVWR. Am I doing the math wrong here? Stateamind has already proven to me on other issues that they are not someone I want to work with ever again - so is it time for me to involve a lawyer? I highly doubt Stateamind will offer me a new, properly sized trailer. I'm obviously going to order another axle, so I can at least move the boat again - but if the trailer is the wrong size, its seems to be a short term fix.
Any advice, comments, etc - are greatly appreciated. Even with all my hassles - Tige and EZLoader have been great.
Thanks
Thanks
