Serpentine Belt Removal
    Do I need anything special to take my serpentine belt off? (350 MPI Mercrusier, 98 2200V). I am taking my alternator off
    Thanks
    Bakes
    You'll need a tensioner adapter for your socket wrench set. You'll want to loosen that before removing the alternator. Pay close attention to the way the serpentine belt is run...it can be a little confusing.
    When you put it on, take the tensioner tool with you in case you need to tighten it when you're on the water.
      my merc had a sticker showing how the belt run.
      the main thing like dogbert said is making sure you get the tension back. if you dont it wont spin the belt.
        He's got a V-Drive, so unless you're a midget, you're not gonna see the sticker (because it's in the back).
          Thanks y'all....now I remember why I wanted a direct drive. I should have stuck to my 22I guns and engine access would have been cake.
