Originally posted by Joeprunc
View Post
Boat top speed 10 mph!
Originally posted by goboardgo View PostOK, Today I put the boat in the water with the pressure gauge attached to the fuel rail. I'm not sure what my pressure is supposed be (I'm thinking it's supposed to be around 38 - 42 PSI) I have 30 PSI at idle and it drops to 24 PSI under load. That sounds low, is it?Cursed by a fortune cookie: "Your principles mean more to you than any money or success."
I have seen marine fuel hose deteriorate internally that will cause problems with fuel pump, siphon valves, filters etc. The ethanol added to gasoline will make this problem worse. I don't know the layout of your fuel system, can you disconnect the fuel hose close to the tank and blow back into the tank with low pressure air? This would clear fuel tank pick up (there was reports of some boats with contaminants plugging or partially obstructing the pick up. I would work from the tank to the fuel pump trying to make sure fuel flow is not obstructed. If the hose and piping are fine then I would change the fuel pump. Lately in our area of NC there has been a bunch of cars and trucks that have suffered fuel pump failures (My Father in law runs a towing company) do to ethanol and the baggage that comes with it. Good Luck
