Tige Gauge problems
    Tige Gauge problems
    I have a 2004 Tige and I have been having problems with a couple of my gauges.
    The water temp gauge needle has started to jump to different numbers and sometimes does not move at all but the boat is not running hot. I replaced the sending unit and that did not help. I have also put in a separate temp gauge that has a sensor that goes into a access hole near the top of the engine. this gauge shows that the water temp is fine so I have been able to watch the temp but I want my factory gauge to work like it should. (the other gauge is lying in the floor)
    My second problem is the oil pressure gauge. it maxes out to the highest number but the boat is running fine.
    Please help.
    the gauges are driving me crazy.
    Greg
    A ground lead for those two gauges may be loose.
    Double check all the wires from the gauges and make sure all the connections are tight.
    The wires to those gauges are probably daisy chained from other gauges, except for the sensor leads.
      clean all the connections first
      HUMAN BUILT = HUMAN FIXED
      switchbait.com
