I have been searching the forum for a problem like mine. I haven't found it so I will post my problem
I move the taps either up or down and I get no movement of my taps plate. I do hear a clicking under my dash. Which I have traced it to a little module under my dash which I think is for the taps. Does any one know how to bypass the the switch and module to see if it is my switch/module or the pump. I have hydraulic ramps (2). I have checked fluid and that is good.
I am a little concerned about my pump due to my drain plug falling out and half of my engine compartment was under water and so was my pump. After this happened I checked if for water and didn't find any.
Any help would be great.
Sam
Sam
