I like many others have had quite a few problems with my gauge not reading continuously after two costly trips to the dealer I fianlly started looking at things for my self. I noticed that when I knocked on the gauge it seem to work at times but not always I checked all the wires leading to the gauge and found them ok I did notice that the mounting bracket that held the unit appeared to be a little lose I tighten it up and haven't had any more problems I hope this info will help some of you with the problems you have or maybe a preventive maintenance check at the start of the season.
Good luck
Good luck
