I am looking for a starter/solenoid assy, distributer cap and rotor for my 2002 23V. Motor is 5.7 liter throttle body injection I believe. I have the hull # however the mercruiser website lists everything buy motor serial #. Where on the motor do I find that or is there something I can look up buy my hull #?
Engine Serial #?
Originally posted by radackj View PostI am looking for a starter/solenoid assy, distributer cap and rotor for my 2002 23V. Motor is 5.7 liter throttle body injection I believe. I have the hull # however the mercruiser website lists everything buy motor serial #. Where on the motor do I find that or is there something I can look up buy my hull #?
Look for the engine serial number, etc., on the port side of the large plastic "air cleaner" that you have to take off to see the intake manifold.
Mine's an '02 as well, a 315 MPI, and it has sequential injection. You should see four injectors on each side of the intake manifold up against the valve cover.
