ok... to all you service guys- I've got a question about TAPS2 wiring.
Does the TAPS system on the '04 and later boats have a specific connection on the battery side? Mine was intermittently working this past Sunday (its stuck in the up position) and I couldnt find anything loose under the dash. The only thing I can think of is that I might have knocked something loose when I removed the battery tender clamps from the batteries, then put the battery box covers on in a hurry to get on the water.
Any ideas that I should check for? If theres a seperate circuit, I'm assuming that it'll be on battery #1 with the mess of others (I've got the factory dual battery setup).
