Boat is a 2003 Tige 22V. Had this happen the last two times out at the lake.
I have two batteries in the boat, tied through a 1/2/All/Off battery switch. Both batteries were charged and tested before our last outing. I had battery #2 selected at the time, and tried to start an electric air pump to blow up a tube, plugged in to the cigarette lighter on the dash below the ignition switch. The pump started up, and died immediately. Once that happened, the boat lost all electrical power. No crank with the key, no accessories powering on, nothing. The only hint of electrical power left was the TAPS actuator trying to return to startup position upon key-on.
I dug around for awhile, checked all the fuses and breakers that I could find. No bad fuses, no tripped breakers. Tried switching to battery #1 (which was good), no change. Selected "all" on the battery switch, no change. Finally decided to turn the ignition with the key and try to jumper the starter solenoid to get the engine to start. As soon as I touched the positive battery lead to the solenoid power, EVERYTHING electrical on the boat came back on. From then on, it would start just fine with the key.
I started the engine, put the drive in neutral and ran the RPM's up to make sure that the alternator was charging fully, then tried to run the air pump off the cigarette lighter again. Whatever it was that kicked off the first time (breaker??) kicked off again, and the engine died immediately. Same symptoms...no electrical power to anything. Did the same thing with jumpering the starter solenoid, and it all came back on fine again.
What the hell is going on????
