Crimping connectors on large wire
    What do folks use for crimping connectors onto 2/0 to 4 gauge wire? The tools I have found online are $$$$! There is a hammer tool that I've found for significantly less. Anyone use something like THIS?
    That tool works good.
    What I like to do is clamp the terminal eye in a vise, heat it with a butane torch and fill it about 1/4 to 1/3 full with liquid solder and then slide the spliced end in and let it cool. When cool, cover with heat shrink.
      I actually have the crimp tools for those big connectors, but I guess being in the electrical trade helps. Try using the vice idea or you might have to find some type of bolt on connector.
        jwanck11 - I used that tool and the connectors did not come loose. It worked very good.
          Cool! Thanks very much for the responses. I was actually thinking of doing a blend of methods using soldier and then crimping. Always woried about a cold solder connection...
            My dealer had a crimping tool and, since I got some of the cable from them anyways, they just did it for me.
              Originally posted by jwanck11 View Post
              Cool! Thanks very much for the responses. I was actually thinking of doing a blend of methods using soldier and then crimping. Always worried about a cold solder connection...
              As long as you heat the connector to the point that the solder melts as you touch it to the inside, it should be a good solder.
                I bought the same hammer crimper for 2 ott O rings. I bought it from this place cheap: https://weldingsupply.securesites.co...20940:OR:04040
                  wow - that is a great price!
                  I do have a fair amount of experience with soldering but did have one or two bad solders when I used to make r/c batt packs. That is why I thought about doing both...
                    IMO, this is the most professional looking way and makes the joint totally secure. I did exactly that on all of mine (lots!) I went one step further though, and used a vice grip plier with a round mouth to squeeze them shut--adjust the knob so it's tight then close the pliers using thier leverage to close the gap in the terminal. Then put the supplied red/black boot over the end.
                    Looks VERY good and literally held me (180#) from the terminal ring--that's secure.
                      Unless you have one HELLUVA soldering iron, you'll have to use a propane/MAPP gas torch and solder. I would just use the torch; makes it quick and easy.
                        Thanks Jason... that is basically the same thing that I am going to do but instead of using vise grips, I am thinking of using the hammer crimper. The pull strength is rated at 1800#'s
                          last question on this. Do you guys use an electrical solder (higher silver content) or regular plumbing solder?
                          I have a hard time locally finding electrical solder in quantity
                            Resin core, NOT Acid core.
                              Thanks! Will take a look at the stuff I have.
                              I am used to the small RC and model train boards where I use electrical solder and to plumbing as well. Not sure I ever took notice of resin vs. acid core.
