I have a 2002 22i type R and I am having issues with my boat lighting. When i flip the cyst light switch the in-boat accent lights illuminate; however, I am not seeming to get any lighting from my front two lights or my light rod in the back. Is there a fuse that might be out for these, I checked the small fuse box that said cyst light, not blown. I have also tried turning on the acc switches, no luck. Please help
Boat Lighting Issue
Your accent lights should be on a totally different switch than your nav or anchor lights. Are you saying that the switch light illuminates, but you have no light at either the bow or stern anchor light?Cursed by a fortune cookie: "Your principles mean more to you than any money or success."
On my 2004 21i I have a switch for the courtesy lights which are the led lights in the boat around the floor.
The switch for the bow lights (red and green) and the stern (white light) are on the switch labeled NAV/Anchor lights.
Your navigation and anchor lights should be completely independant of any other lights in the boat. It is a three position switch. In the up position it will turn on your navigation and anchor lights, in the down position it will just turn on your anchor light (solid white ) and in the middle they should be off.
I hope this helps.
Originally posted by Chill0987 View PostI have a 2002 22i type R and I am having issues with my boat lighting. When i flip the cyst light switch the in-boat accent lights illuminate; however, I am not seeming to get any lighting from my front two lights or my light rod in the back. Is there a fuse that might be out for these, I checked the small fuse box that said cyst light, not blown. I have also tried turning on the acc switches, no luck. Please help
If so, they will have their own switch(s) marked NAV and or ANC. It's best to not to have lights on in the boat while underway, kinda kill your night vision, so that is one reason the CTSY lamps and NAV/ANC lamps are on different switches.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by Chill0987 View Postthanks guys, i feel extra stupid that i was just using the wrong switch. The nav anc switch worked perfect. Thanks again!
I would look for an entire light assembly that will fit the footprint of the old light.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
