fuel gauge not working
    The fuel gauge on my '02 20V is not working. This is a cluster gauge, fuel is the only one not working
    I found a loose black wire (I think the other end is grounded) and attached it to the fuel gauge and now it reads full all the time.
    Has anyone seen this? I winterized it last fall with less than a 1/4 tank of gas. Could this have anything to do with it? Thanks.
    Tom
    How much gas is in the tank now (did you fill it since winterizing) ?
    what did the gauge read before you attached that wire?
    what did the gauge read before and after filling (if done)
    Here is a "How To" on testing gauge and sending unit http://www.tigeowners.com/forum/show...7&postcount=18
      I have filled up the tank several times this year, gauge still reads empty.
      The gauge always read empty before attaching the loose wire.
      Gauge did not move when filling the tank. It has only moved to full after putting on the loose ground wire.
      I thought it was fixed, after running all day it did not go down.
      Thanks for the link.
      Tom
        Does anyones flue gauge ever really work????
          Mine reads full 95% of the time and when I am down low on fuel, that damn gauge goes south very quickly.
            Mine does
            Sounds like the float is either stuck @ EMPTY or FULL. I dont think that black wire needs to be there. The only ground on the gauge would be for the back-light.
            Let me know if you need any help walking through testing.
              Mine does.
                it hasn't yet.. but hopefully after I give it to the dealer it will.. (fingers crossed)
                If you ain't falling.. you ain't trying hard enough..
