Stereo Help
    Stereo Help
    So today my speakers crapped out on me. They were working fine and the boat was off so then i start the engine and the speakers just crap out on me i tried every possible button on the stereo checked every speaker, and nothing came out, not even static. The wierd thing is my head unit still has power. So i have no idea whats wrong. Thanks
    Do you have an amp?
    Common Sense is not so Common
      Yes
        yeah its a kicker 350A or something like that
          Have you tried the stereo since this happened? Sometimes when Im listening to the radio and then start the engine the amp doesnt turn back on, Or check all wires to the amp. Hope that helps, Its all I can offer.
            Your amp probably isn't turning on. Either that or your signal leads are not plugged in. Check the amp to make sure it has a power indicator light or similar (protect mode) on.
            http://www.wakeboatworld.com
            []) [] []V[] [])
