Sub/tower speaker wiring?
    Need some help here. I have one RF 300 watt amp powering my tower speakers, and I am going to add analpine 600 watt amp to power a boston pro 10.5lf. I ran 4 guage power and ground to distribution blocks, then 8 guage to the amps. I hooked up the RF amp to an accesory switch, my question is will it work to hook up the alpine amp to another accessory switch? I am concerned that if I turn the RF amp on for the tower speakers, but leave the alpine amp off it might mess something up since they are powered thru the distribution block. Another question is that I put the amps in the compartment in front of the driver, will this mess any dash guages or PP up with the power so close? Sorry for the long post.
    We have installed amps in that compartment before and never had a problem with anything. On the other issue if you run the remote turn on wire to the dash switch it should work with no problem.
      Thanks lee, always good to hear I won't mess anything up!
