I am having issues of the radio not holding the stations after i set them and then turn the power off. I checked the inline fuses for both the red and yellow wire. I changed them to make sure but no change. What does the yellow wire usually tap into when it is factory installed. It looks like it was tapped into an orange wire. What other things can i check to see what is going on? Does anyone know what the orange wire goes to or from?
clarion loses presets
I have 03 20v and I also had the same problem, the red and yellow wires were switched, they had the correct lable but the red wire had power all the time and yellow wire was hot with key on. switched wires in tiges harness and it workes great."I refuse to answer that question on the grounds that I don't know the answer."
I switched the wires at the radio plug. Red to yellow, Yellow to red. It works great now, you may also want to disable the face plate in beep.
with the deck wired correctly it may beep or chime every time the key is turned off."I refuse to answer that question on the grounds that I don't know the answer."
Pull the pins out of the connector and switch them, or just cut cut them and butt connector them back together, use some heat shrink arount the connector. The wire is probably 16 or 18 gauge, its ok to use larger wire if its all you have just dont use anything smaller. I dident need to add any wire just switched pin locations in the connector."I refuse to answer that question on the grounds that I don't know the answer."
