I just replaced all of my instruments on my boat. The Gas gauge is reading backwards. When the tank is full it shows empty on the gauge. When the tank is empty it shows full. I made sure my wires are connected right. I used OEM parts. I called the manufacture and they said the sending unit in my tank is backwards. I asked how that could be when all I did was replace the gauge. I did not get an answer. Also, when I was out late on the water the gauges started to fog up, Why?
Gas Gauge
Is your unit bad? Most instruments are going to be plug and play to the unit that is already in the tank. From what I researched there are only 2 ranges. One is for gallons, and one is for liters. The standard/American gauge is 240-33 ohms. Metric is a different range.Last edited by spharis; 06-18-2007, 05:52 PM.http://www.wakeboatworld.com
[]) [] []V[] [])
