Taps control box
    Taps control box
    Hey guys
    I have a 2005 20v and they control box for my taps has been bad for a couple years now. I contacted Lenco to find out the have discontinued the original and the replacements boxes and don't have a solution to my problem. Anyone have a wiring diagram for a three position rocker switch to bypass so I don't have to touch the wires back and forth to the spare battery anymore. I do know ill lose the taps guage but I visual adjust anyways. Thanks in advance.
    A pair of relays wired to reverse polarity should work to drive the motor using the original switch in the throttle.
      Thank you Chpthril ill check into that
        Two outputs are the outer leads on your switch. Your middle lead on your switch will need to go to ground or tie into your connection on 87a, whichever is easier at the time.
        Oh Yeah!
          Thanks Koolaid !
